happygamer
Oct 18, 2026Aspirant
CM1200 to Orbi 370 no internet
Cables are all checked. When connecting CM1200 directly to PC (all ethernet cables), instantly internet access Setting up the Orbi 370 from CM1200, has wifi but no internet. Have done all the re...
happygamer
Able to set up with wifi using browser instead of the app and checked the internet port. All are 0. The external ip, gateway ip, subnet mask, and DNS. It seems it's not registering to modem.
- FURRYe38Oct 18, 2026Guru - Experienced User
Be sure you are connecting the RBR to number 1 WAN port on the back of the CM1200 modem, there are 4 WAN ports there I believe the top most port is port 1.
- happygamerOct 18, 2026Aspirant
Ya, it's always been modem 1 to router as that's how it was on my R7000
