happygamer
Oct 18, 2026Aspirant
CM1200 to Orbi 370 no internet
Cables are all checked. When connecting CM1200 directly to PC (all ethernet cables), instantly internet access Setting up the Orbi 370 from CM1200, has wifi but no internet. Have done all the re...
Oct 18, 2026Guru - Experienced User
happygamer wrote:Setting up the Orbi 370 from CM1200, has wifi but no internet.
Just to be certain:
- you hooked up the 371 (router) to the CM1200? Not the 370 (satellite)?
- and you connected to the bottom ethernet port (right above the power connector)?
Are you able to log into the router's web admin page?
- happygamerOct 18, 2026Aspirant
It's the router. I haven't touched the satellites yet until I establish internet connection
