ggb1979
Dec 15, 2025Aspirant
Confused by legacy network extenders still connecting
hi would appreciate some advice I am UK based, with vodafone fibre 500 connection. Recently purchased orbi 370 with 1 base unit and 2 satalites to replace the vodafone default router and voda...
Dec 15, 2025Guru - Experienced User
Did you perhaps set up the guest and iot network to use these _EXT SSIDs???
ggb1979
no didn't set that up at all. There is no guest wifi set up
I am tempted to re-do set up and call my network something complete different then manually re-add everything
