ggb1979
Dec 15, 2025Aspirant
Confused by legacy network extenders still connecting
hi would appreciate some advice I am UK based, with vodafone fibre 500 connection. Recently purchased orbi 370 with 1 base unit and 2 satalites to replace the vodafone default router and voda...
ggb1979
Dec 18, 2025Aspirant
Hi sry if I’ve not been clear in updates. When I turned everything off all the networks eventually disappeared
I then turned just the open reach modem back on and left it 30mins - no networks appeared
I factory reset the Orbi router and satellites . Deleted the app. Reinstalled and did a fresh set up of the Orbi kit using the default Orbi settings for ssid and password
it is 100% the Orbi producing these networks
it is also producing a NTGRBH…… network
as far as I can tell all the networks are coming from the router and the satellites
Dec 18, 2025Guru - Experienced User
What FW version is on the RBR and RBS?
I've not seen this with my 370 series. Odd.
Where did you pick up this 370 series?
So have you changed the main WLAN SSID name to something other than Orbi36 and the _5GEXT and _EXT still remain?
