ggb1979
Dec 15, 2025Aspirant
Confused by legacy network extenders still connecting
hi would appreciate some advice I am UK based, with vodafone fibre 500 connection. Recently purchased orbi 370 with 1 base unit and 2 satalites to replace the vodafone default router and voda...
CrimpOn
Dec 19, 2025Guru - Experienced User
Yes, the goal is to compare those hardware MAC addresses with the WiFi access points which are broadcasting those "EXT" WiFi networks.
For example, when the system has a Guest or IoT WiFi network defined, the access points will broadcast those WiFi SSIDs as well, and they will come from the same MAC address as the primary WiFi network. If the new ORBI36 device is broadaasting the "EXT" and "5GEXT" WiFi networks, all of these networks will come from the same hardware address.
If they come from wildly different addresses, that supports the concept that they are coming from a different hardware device.
- ggb1979Dec 20, 2025Aspirant
Hi this is what WiFi scanner shows
the MAC address for _ext and _5gext are the same but don’t match any of the orbi macs
they also don’t match the macs of anything else on my network
Tell a lie using device manager on the Orbi app I’ve found 2x tenda devices each with the matching mac code
these are not separate physical devices I promise there is nothing physical in my house I am not aware of
these are somehow integral in the satellites
i
