Dadorder
Nov 20, 2025Aspirant
Connecting a Lutron hub to an Orbi Satellite
Maybe someone has run into this configuration? We have a Lutron (home lighting system) which we will install in a utility building, away from our house. The Lutron Caseta hub (which all the light...
Dadorder
Nov 21, 2025Aspirant
Thanks. The utility building is about 130 - 150 ft away. I will be daisy-chaining the RBS'.
Nov 21, 2025Guru - Experienced User
That maybe to far way in between one RBS and another. I guess give it a try and if it fails, you'll need to look to something else to get signal out to the remote location. Point 2 Point wireless system maybe needed to get something out that far.
- DadorderNov 22, 2025Aspirant
I may need to do that. I have the Orbi router in a room at the front of the house, and a RBS at the back of the house. I have another RBS daisy chained in a shed by our pool (30-40 ft away). The RBS I plan to put in the utility building will be ~40 ft further. So it will be interesting :)
