Tartolini
Aug 04, 2025Aspirant
Connection
Hello guys, I want to jump to Orbi 970 but I have one qestion before purchasing. Will Orbi 970 run on below setup? PR60X-->GS724TPv3-->ORBI (router) + 2 satelites? Like in drawing. Thanks f...
Tartolini
I need minimum 3 ethernet ports at each end. From what I've seen for example wbe750 doesn't have extra ones.
I also want wifi 7 so from AP that netgear provides I can only use WBE750 or WBE710.
Aug 04, 2025Guru - Experienced User
Could install some non managed switches at the remote ends for additional ports. Something small with 5 or 8 ports?
Since the WBEs are mostly PoE supporting and only have 1 LAN port, could get a PoE switch as well at the remote location to connect a WBE at the remote location.
I have a GS305P I use when I have one of my WBEs deployed.
