manj_dosanjh
Feb 01, 2026Aspirant
Constant intermittent connection - specifically with the PS5.
Hi, just upgraded from Nighthawk to Orbi. Nighthawk system with extender was ok but it kept resetting to old password and couldn’t ever work out why. New system was set up and for a few days ...
- Feb 02, 2026
Have you tried disabling Netgear Armor? I had to disable it with my 970 as Armor was seeing some devices as a threat and not allowing a connection. The PS5 was one of the devices it would happen with, but now with Armor disabled, it will stay connected all day long.
Feb 01, 2026Guru - Experienced User
What Orbi model # do you have?
FIrmware loaded on it?
Is the PS console connected to the RBS or the RBR?
Is the PS wireless or ethernet connected? Ethernet is recommended to the RBR.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Is IPv6 enabled on the RBR?
Using ISP detected DNS or custom DNS?
manj_dosanjh
FYI I am from the UK.
Orbi 970 with a satellite (RBE971 and RBE 970)
Both 9.13.2.1
So how can I work this out? Also I took the advice of a previous device and added the IoT network and the ps5 is connected to that - nothing else.
Wireless
Assume RBR means the main router?
1
I think 2,300 roughly (5 bed house)
So it’s close to that around 10 meters one side of the house to the other. FYI ps5 is the middle of the two.
So I don’t really know what you mean? It’s Virgin Media is the ISP. Their router is called the HUB 5. I turned it modem only so I could use Orbi. Does that help?
How do I check?
Not a clue 😂 - how do I check?
Sorry - I am a little technical but not 100% like you above - thanks in advance 🙏🏽
- JJG1992Feb 02, 2026Apprentice
- manj_dosanjhFeb 02, 2026Aspirant
Interesting - I will try it - but the issue is it’s intermittent not constant so not sure. But worth a shout.
I would also suggest setting up a BQM (Broadband Quality Monitor). You mentioned your ISP is VM; I was a super user on their community. I would also have the Hub 5 power levels checked. Power levels too low on your downstream and upstream can cause packet loss and game dropouts, mostly at peak times.
- FURRYe38Feb 02, 2026Guru - Experienced User
Does PS show up on the RBRs web page or on the RBS web page?
Wireless
Can you try ethernet connected?
YES.
1
Yes.
How do I check?
On the RBRs web page under Advanced Tab/Advanced/IPv6
Not a clue 😂 - how do I check?Probably ISP if you don't know. Most would be using ISP DNS. Would be on RBRs web page under Advaned tab, Internet section.
Is ARMOR enabled on the system?
- manj_dosanjhFeb 03, 2026Aspirant
Hi,
I know what you mean now - i will test this weekend as i am away.
A pain - but i agree i need to try this to remove why i am having this issue.
It says disabled.
So in basic tab, internet section - it says Internet IP address - "Get Dynamically from ISP" and under Domain Name Server (DNS) Address - "Get Automatically from ISP" - is this what you mean?
It was - but i disabled it last night to see if that helps.
- FURRYe38Feb 03, 2026Guru - Experienced User
It was - but i disabled it last night to see if that helps.Yes.
Let us know how it goes with it disabled...
