PimpDiggler
Jul 03, 2025Guide
Continuously disconnects wifi connections with my Pixel 9Pro XL
I will be downgrading this version continuously disconnects wifi connections with my Pixel 9Pro XL is there a link to the 9.12 version before this I can downgrade to
TOPS119
Jul 03, 2025Luminary
I have a 9 pro xl as well im not facing that issue on the new firmware... This might be something we need to look further into
PimpDiggler
Jul 03, 2025Guide
I still have ipv6 enabled and it was enabled in the last firmware as well and I didnt see nearly the disconnects I am seeing since upgrading
- FURRYe38Jul 03, 2025Guru - Experienced User
Have you done a factory reset and setup from scratch after v.2 FW was loaded to see if problem still happens?
- PimpDigglerJul 03, 2025Guide
Yes I have setup the router from scratch after loading the latest firmware. I only have the 970 providing wifi for all my devices and usually I am seated in front of the router (line of sight) when these disconnects are happening. I am running Android 16
OK, thank you for confirming that.
Does this happen with the RBS turned off?
What channels are you using on the RBR?
Also someone reported changing the WPA settings to WPA3 only on the main WLAN and setting up IoT network for those devices that don't support WPA3. User saw good connections with there new gen Apple devices. Wondering if you could give this a try as well?
