Nobber1066
Nov 23, 2025Aspirant
Devices on network not showing up
Orbi 970 1 router 4 Satellites Firmware V9.13.2.1 Why do I have wireless devices on my network which dont show up on the web interface or in the mobile app They previously shown and are co...
- Nov 23, 2025
What brand and model# wireless devices are not showing up?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?What Firmware version is currently loaded?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.What is the size of your home? Sq Ft?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite🛰
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Nobber1066
OK my Bad, Device said connected and working but it turns out it wasnt
Sorry for the wild goose chase
Nobber
Nov 23, 2025Guru - Experienced User
Glad you figured it out.
Enjoy. 📡
