TOPS119
Aug 04, 2026Luminary
Did anybody with samsung s25 phones figure out how to connect to wifi 7
I had a s25 ultra which when connected only shows wifi 6. I now get a s25 and im only seeing wifi 6 went to the lab and wifi 7 is turn on so is there something im not doing?
TOPS119
Aug 05, 2026Luminary
Yes there is definitely something going on with the Samsungs and my orbi this is my third device and it's the same issue. Orbi says I need to purchase there service for 99 dollars before they can help me lol I find that crazy smh.
Aug 06, 2026Guru - Experienced User
TOPS119 wrote:Yes there is definitely something going on with the Samsungs and my orbi this is my third device and it's the same issue. Orbi says I need to purchase there service for 99 dollars before they can help me lol I find that crazy smh.
Might be worth trying a test with the wifi security set to wpa3 (not mixed).
- TOPS119Aug 06, 2026Luminary
I did with the lot network and then the lot network disappeared....it's not even seeing the lot anymore.
- StephenBAug 06, 2026Guru - Experienced User
Are you seeing the IoT network on any other devices? Does it re-appear if you reapply the original security setting?
Unfortunately, you seem to facing an unusual number of issues recently.
Yes the other devices see the lot network, and it reappear after placing it back. Actually I've faced faced 2 issues recently one in which the new firmware fixed and now this.
