TOPS119
Aug 04, 2026Virtuoso
Did anybody with samsung s25 phones figure out how to connect to wifi 7
I had a s25 ultra which when connected only shows wifi 6. I now get a s25 and im only seeing wifi 6 went to the lab and wifi 7 is turn on so is there something im not doing?
TOPS119
Aug 07, 2026Virtuoso
I notice something the region of my router says united States, I am in the Caribbean would that affect the 5g network not connecting on my samsung? But yet it connects on other devices ?
- schumakuAug 07, 2026Guru - Experienced User
Don't know the regualtory requirements for the Caribbeans - and if Netgear does have options (what is always difficult, because of the US FCC regulatory devices don't allow regulatory region changes at all.
The Federal Communications Commission (FCC) regulates telecommunications and radio services only in U.S. Caribbean territories, such as Puerto Rico and the U.S. Virgin Islands.
Independent Caribbean nations (like Jamaica, Trinidad and Tobago, or Barbados) have their own sovereign regulatory bodies and are not subject to U.S. FCC.
So that can make a big difference ...
- StephenBAug 07, 2026Guru - Experienced User
Most islands are the same as US (FCC), Dutch and French islands are the same as Europe (ETSI). Either way, channel 44 is available in all countries, so geography is not a factor.
TOPS119 wrote:
intelligent wifi doesnt seem it has an option to toggle on and off..
Google says
- open Settings, tap Connections, select Wi-Fi,
- tap the three-dot menu in the top-right corner,
- choose Intelligent Wi-Fi
- TOPS119Aug 07, 2026Virtuoso
Yes I know exactly where it is and thats what google showed you where it is. But as I stated there is no toggle to turn it on nor off
Are there controls there that modify how it works?
- schumakuAug 08, 2026Guru - Experienced User
Nonsense, sorry. A single common 5 GHz channel isn't enough. On one hand, the backhaul on 5 and 6 GHz (is this DFS now?) requiring at least 160 MHz bandwidth, and then the front end, which does again require yet another 160 MHz bandwidth.
Sure location is a factor here: ETSI and FCC systems don't co-operate as we perfectly see on the OP case.
