TOPS119
Aug 04, 2026Virtuoso
Did anybody with samsung s25 phones figure out how to connect to wifi 7
I had a s25 ultra which when connected only shows wifi 6. I now get a s25 and im only seeing wifi 6 went to the lab and wifi 7 is turn on so is there something im not doing?
Aug 07, 2026Guru - Experienced User
TOPS119 wrote:I notice something the region of my router says united States, I am in the Caribbean
Most islands are the same as US (FCC), Dutch and French islands are the same as Europe (ETSI). Either way, channel 44 is available in all countries, so geography is not a factor.
TOPS119 wrote:intelligent wifi doesnt seem it has an option to toggle on and off..
Google says
- open Settings, tap Connections, select Wi-Fi,
- tap the three-dot menu in the top-right corner,
- choose Intelligent Wi-Fi
TOPS119
Aug 07, 2026Virtuoso
Yes I know exactly where it is and thats what google showed you where it is. But as I stated there is no toggle to turn it on nor off
- StephenBAug 07, 2026Guru - Experienced User
Are there controls there that modify how it works?
