TOPS119
Aug 04, 2026Virtuoso
Did anybody with samsung s25 phones figure out how to connect to wifi 7
I had a s25 ultra which when connected only shows wifi 6. I now get a s25 and im only seeing wifi 6 went to the lab and wifi 7 is turn on so is there something im not doing?
Aug 07, 2026Guru - Experienced User
TOPS119 wrote:I notice something the region of my router says united States, I am in the Caribbean
Most islands are the same as US (FCC), Dutch and French islands are the same as Europe (ETSI). Either way, channel 44 is available in all countries, so geography is not a factor.
TOPS119 wrote:intelligent wifi doesnt seem it has an option to toggle on and off..
Google says
- open Settings, tap Connections, select Wi-Fi,
- tap the three-dot menu in the top-right corner,
- choose Intelligent Wi-Fi
schumaku
Aug 08, 2026Guru - Experienced User
StephenB wrote:Most islands are the same as US (FCC), Dutch and French islands are the same as Europe (ETSI). Either way, channel 44 is available in all countries, so geography is not a factor.
Nonsense, sorry. A single common 5 GHz channel isn't enough. On one hand, the backhaul on 5 and 6 GHz (is this DFS now?) requiring at least 160 MHz bandwidth, and then the front end, which does again require yet another 160 MHz bandwidth.
Sure location is a factor here: ETSI and FCC systems don't co-operate as we perfectly see on the OP case.
- StephenBAug 08, 2026Guru - Experienced User
TOPS119 - did you have this problem before Netgear told you to reset the router 5 ghz wifi channel to channel 44? Does changing it to "Auto" make any difference?
- TOPS119Aug 08, 2026Virtuoso
They change to those channels because auto gave slow speeds even after the reset. So auto made no difference
You might try 149, and see if the phone "sees" that.
