TOPS119
Aug 04, 2026Luminary
Did anybody with samsung s25 phones figure out how to connect to wifi 7
I had a s25 ultra which when connected only shows wifi 6. I now get a s25 and im only seeing wifi 6 went to the lab and wifi 7 is turn on so is there something im not doing?
TOPS119
Aug 08, 2026Luminary
They change to those channels because auto gave slow speeds even after the reset. So auto made no difference
Aug 08, 2026Guru - Experienced User
TOPS119 wrote:They change to those channels because auto gave slow speeds even after the reset. So auto made no difference
You might try 149, and see if the phone "sees" that.
- TOPS119Aug 08, 2026Luminary
These are the only channels available for me to choose from
- FURRYe38Aug 08, 2026Guru - Experienced User
IF you set up the IoT network for a 5Ghz SSID and set OPEN security temporarily ON the 971, Does your one phone see the 5Ghz SSID name and can it connect to it?
Then set the IoT network for WPA2 and see if it will connect to it?- TOPS119Aug 08, 2026Luminary
I don't have the option to do open security. Where would I find that ?
