TOPS119
Aug 04, 2026Virtuoso
Did anybody with samsung s25 phones figure out how to connect to wifi 7
I had a s25 ultra which when connected only shows wifi 6. I now get a s25 and im only seeing wifi 6 went to the lab and wifi 7 is turn on so is there something im not doing?
TOPS119
Aug 13, 2026Virtuoso
So just an update still haven't gotten this thing fix, But was trouble shooting and saw there was an update on one of the samsung s23 ran the update when it came up it had wifi 6e on the wifi sign which was different so I went and check what it was connected to via the website it was connected to the 6ghz network..So happy that I finally got it to work there was another update ran the second up date phone came up and was connected back to wifi 6 @ 2.4ghz so I am back to square one.
- FURRYe38Aug 13, 2026Guru - Experienced User
I sent you a PM.
Do you have a case already open with NG on this?
- TOPS119Aug 13, 2026Virtuoso
Yes and I responded to your pm 3 times and yes a case is open. But what I relay to you guys just now they are not aware. As the agent told me it was a region block which is not true
- FURRYe38Aug 14, 2026Guru - Experienced User
Ok so I haven't received any responses from you in my PMs. Zero.
This is a Samsung regional issue. Since I have a 25s working here in the NA region on my 970 series, and others are as well. Seems to be a problem in your region since your the one one posting about having this issue.
You'll nee to work with Samsung and NG on this as all this is beyond forum help.
Good Luck.
