TOPS119
Aug 04, 2026Virtuoso
Did anybody with samsung s25 phones figure out how to connect to wifi 7
I had a s25 ultra which when connected only shows wifi 6. I now get a s25 and im only seeing wifi 6 went to the lab and wifi 7 is turn on so is there something im not doing?
Aug 13, 2026Guru - Experienced User
I sent you a PM.
Do you have a case already open with NG on this?
TOPS119
Aug 13, 2026Virtuoso
Yes and I responded to your pm 3 times and yes a case is open. But what I relay to you guys just now they are not aware. As the agent told me it was a region block which is not true
- FURRYe38Aug 14, 2026Guru - Experienced User
Ok so I haven't received any responses from you in my PMs. Zero.
This is a Samsung regional issue. Since I have a 25s working here in the NA region on my 970 series, and others are as well. Seems to be a problem in your region since your the one one posting about having this issue.
You'll nee to work with Samsung and NG on this as all this is beyond forum help.
Good Luck.
- TOPS119Aug 14, 2026Virtuoso
ok here it is since pm obviously not working
Thanks, will have a moderator check in on why PMs are not working. Please don't post email addresses or phone numbers in pictures in public forums for security reasons.
Will have moderator remove that picture.
Keep in contact with Samsung and NG support.
Good Luck.
