TOPS119
Aug 04, 2026Virtuoso
Did anybody with samsung s25 phones figure out how to connect to wifi 7
I had a s25 ultra which when connected only shows wifi 6. I now get a s25 and im only seeing wifi 6 went to the lab and wifi 7 is turn on so is there something im not doing?
Aug 15, 2026Guru - Experienced User
There has been no MLO adjustments on BE systems.
There is the following under Advanced Wireless:
Advanced Wireless Settings (5 GHz 802.11a/n/ac/ax/be)
Enable 240MHz Bandwidth check box.
Not sure if this would be helpful.
TOPS119
Aug 15, 2026Virtuoso
Had check this option on and off with no success as well.
