TOPS119
Aug 04, 2026Virtuoso
Did anybody with samsung s25 phones figure out how to connect to wifi 7
I had a s25 ultra which when connected only shows wifi 6. I now get a s25 and im only seeing wifi 6 went to the lab and wifi 7 is turn on so is there something im not doing?
Alexander21
Aug 19, 2026Aspirant
Yes, I’d like to know this too. Has anyone with a Samsung S25 figured out how to connect to Wi-Fi 7? I’m also checking AMTToolsZ for possible solutions.
- TOPS119Aug 19, 2026Virtuoso
What region are you in Alexander21
- schumakuAug 19, 2026Guru - Experienced User
Not all Samsung S25 are supporting WiFi 7. The S25 FE does only support WiFi 6E for example.
I have tested a few with the same result s25 wifi7 s25ultra wifi7 s23 6e
- StephenBAug 20, 2026Guru - Experienced User
Just wondering - if you remove the satellites as a test, do the phones connect at 5 ghz?
If they do, then using a wired backhaul might be a workaround for now.
