TOPS119
Aug 04, 2026Virtuoso
Did anybody with samsung s25 phones figure out how to connect to wifi 7
I had a s25 ultra which when connected only shows wifi 6. I now get a s25 and im only seeing wifi 6 went to the lab and wifi 7 is turn on so is there something im not doing?
Alexander21
Aug 19, 2026Aspirant
Yes, I’d like to know this too. Has anyone with a Samsung S25 figured out how to connect to Wi-Fi 7? I’m also checking AMTToolsZ for possible solutions.
schumaku
Aug 19, 2026Guru - Experienced User
Not all Samsung S25 are supporting WiFi 7. The S25 FE does only support WiFi 6E for example.
- TOPS119Aug 19, 2026Virtuoso
I have tested a few with the same result s25 wifi7 s25ultra wifi7 s23 6e
- StephenBAug 20, 2026Guru - Experienced User
Just wondering - if you remove the satellites as a test, do the phones connect at 5 ghz?
If they do, then using a wired backhaul might be a workaround for now.
- TOPS119Aug 20, 2026Virtuoso
I am using a wired back haul right now so one of my test was to disconnect the wired made it wireless the satalites connected perfectly. But the phone still wouldn't connect to the 5ghz band.
- schumakuAug 21, 2026Guru - Experienced User
This is what I had expected - since (as stated in my post) that the S25 FE does only support 6e, like your S23,
Once you mentioned a decent Google Pixel phone from what I remember - bear with me I've somehow lost track in this lengthy thread. Same issue on the Pixel not able to connect properly,^with full Orbi capabilities, so beyond 2.4, also 5 and 6 GHz.
On a different point, somebody talked of MLO. To my knowledge, Netgear in the co-operation with the chipset vendor, does -not- support MLO, certaily not on the client facing WiFi side. I don't know if and how this applies to the wireless backhaul.
In my earlier test experience of the Netgear WBE7xx devices, I have never spotted that the wireless MLE operation or connections.
