EntropyDF
Aug 14, 2024Aspirant
Disable Wireless Backhaul (RTGRBH_ Network)
I have an RBE771 with with two satellites connected via Ethernet. Everything is working pretty well, no large issues or concerns.
| Hardware Version | RBE771 |
| Firmware Version | V10.5.6.5_2.2.22 |
| GUI Language Version | V4.0.0.22_2.1.30.3 |
| Protection Engine Version | 2.2.214.4/1.0.0.2049 |
Since I am not using the wireless backhaul, can I disable the wireless backhaul network (RTGRBH___), which is annoyingly visible, is there a way to disable it? Is there a reason not to?
I also note the wireless backhaul network seems to follow my normal wifi network in terms of channel selection, even when I manually move it. I would think it would be better if these were on its own, totally separate channel.
Thanks!
David
1 Reply
You can't disable it.
and it changes channels because there isn't a dedicated backhaul like the other versions.
