phands
Oct 01, 2025Aspirant
Does the Orbi 970 series allow SSH or Telnet access?
Hi everyone, I just got a new Wifi 7 setup - 2 970 satellites and an RBE971 router. I upgraded from some fairly old (5 year) Orbi models, and they have always been fantastic. I'm used to bei...
- Oct 01, 2025
When the WiFi6 product line was introduced, command line access to the router was not included as a feature. (not even a 'hidden' feature) Some time ago, Netgear removed telnet access from the WiFi5 models. (there is an unsupported 'hack' that restores telnet on those models.)
Like the WiFi6 products, the WiFi7 products also do not provide command line access to the router.
Bummer.
CrimpOn
Oct 01, 2025Guru - Experienced User
Command line access (either telnet or ssh) is a valuable tool when trying to understand the router and when troubleshooting "issues". The only alternative appears to be opening the case, connecting the Terminal Pins on the circuit board to a USB-TL device, and using ssh. (For the RBR750 product, see this "How To":
Obviously, this is not something the casual (or beginner) user is likely to attempt.)
