Epistrophy
Oct 04, 2026Aspirant
End of service replacement
Hi -- I received a notice that my current Orbi AC3000 system is no longer supported, so I'm looking to replace it with a newer Orbi 770. However, I have a number of IoT devices connected to my cur...
- Oct 04, 2026
Yes you can use prior SSID name and password for your new system. I've been using same SSID on mine for 20 years. Zero issues.
Also if your Orbi AC3000 series is working for you, you could keep it working if you wanted too. Can look into Voxels 3rd party FW for those models. Pretty good stuff and they update the important stuff.
Good Luck.
Oct 04, 2026Guru - Experienced User
Good Luck.
