bullm00n's avatar
bullm00n
Virtuoso
Aug 12, 2026
Firmware 12.1.11.10 iPhone disconnects
After quite a good run with the previous firmware, this update is causing issues again with at least my iPhone.  It randomly disconnects and most times I can toggle the WIFI on the phone a few times ...
  • bullm00n's avatar
    Aug 28, 2026
    Turns out, if IPV4 is set to manual, automatic DNS doesn't work on iPhone/iPad.  The DNS has to be set manually as well.  Not sure why this wasn't a problem with v9.13.2.1, but it is now.
    I cannot replicate this behavior on my PC as there is not an automatic DNS option, DNS must be set manually when setting a manual IP address.
    At any rate, I think this is the solution: when setting a manual IPV4 address on an Apple device, scroll down to the DNS settings and configure the DNS manually as well - Automatic DNS does not work in this case.
    I'll write this down to user error, I guess, uncovered by new firmware behavior.
