bullm00n
Aug 12, 2026Virtuoso
Firmware 12.1.11.10 iPhone disconnects
After quite a good run with the previous firmware, this update is causing issues again with at least my iPhone. It randomly disconnects and most times I can toggle the WIFI on the phone a few times ...
- Aug 28, 2026
Turns out, if IPV4 is set to manual, automatic DNS doesn't work on iPhone/iPad. The DNS has to be set manually as well. Not sure why this wasn't a problem with v9.13.2.1, but it is now.
I cannot replicate this behavior on my PC as there is not an automatic DNS option, DNS must be set manually when setting a manual IP address.
At any rate, I think this is the solution: when setting a manual IPV4 address on an Apple device, scroll down to the DNS settings and configure the DNS manually as well - Automatic DNS does not work in this case.
I'll write this down to user error, I guess, uncovered by new firmware behavior.
bullm00n
iOS 26.6 on an iPhone 17 Pro
I updated via the app and it seemed to go smoothly - all the devices showed the correct FW. I have made no changes to the setup other than that update.
IPv6 is on the router. Channels are 11 and 36.
I have the IoT set to 2.4 GHz and 5 GHz WPA2-PSK and my phone is happy with that and connects OK.
It's the main network that is flakey using WPA3-Personal. For example, right now my phone shows it as connected to the SSID, but the WIFI status at the top of the phone shows no network, only LTE. Yet, my iPad sitting next to the phone is connected to the same main SSID and has no problems. The phone is apparently connected to the router and the iPad to one of the satellites if the connection information is correct.
So, the phone can connect to the SSID but then acts like it has no WIFI even though is shows as connected to the SSID. Power cycling the phone does no good. Rebooting the router fixes it for a while and then the problem recurs. Or, toggling OFF Wi-Fi 6E Mode on the iPhone - not what I want to do. Or sometimes doing nothing but toggling between the two SSIDs (main and IoT) fixes it for a while. I'd say it's random, but that just means I don't know what is causing it yet, so it seems random.
I have not had time to do much troubleshooting and am not sure where to look, other than going back to the previous firmware that had been fine.
- FURRYe38Aug 12, 2026Guru - Experienced User
What happens if you disable IPv6?
Set channels 1 and 40 or 11 and 48?
Set main WLAN network to use mixed WPA2 and WPA3.
Private WiFi Address set to fixed or disabled?
My router is using Channels 11 and 48.
Mixed WPA mode
Iphone 17 Pro Max iOS 26.5.2
Private WiFi Address set to fixed.
Mine was updated via AU using the web ui, then powered OFF then back ON. No factory reset.
