bullm00n
Aug 12, 2026Virtuoso
Firmware 12.1.11.10 iPhone disconnects
After quite a good run with the previous firmware, this update is causing issues again with at least my iPhone. It randomly disconnects and most times I can toggle the WIFI on the phone a few times ...
- Aug 28, 2026
Turns out, if IPV4 is set to manual, automatic DNS doesn't work on iPhone/iPad. The DNS has to be set manually as well. Not sure why this wasn't a problem with v9.13.2.1, but it is now.
I cannot replicate this behavior on my PC as there is not an automatic DNS option, DNS must be set manually when setting a manual IP address.
At any rate, I think this is the solution: when setting a manual IPV4 address on an Apple device, scroll down to the DNS settings and configure the DNS manually as well - Automatic DNS does not work in this case.
I'll write this down to user error, I guess, uncovered by new firmware behavior.
bullm00n
I will give each of these a try, one at a time, and see if anything improves over the next few days...
Starting with mixed WPA2 and WPA3
Aug 12, 2026Guru - Experienced User
If you set WPA3 only on the main WLAN, then if you have other devices that don't support WPA3, those won't connect. Why Mixed WPA mode is preferred on the Main WLAN.
Let us know how it goes.
