bullm00n
Aug 12, 2026Virtuoso
Firmware 12.1.11.10 iPhone disconnects
After quite a good run with the previous firmware, this update is causing issues again with at least my iPhone. It randomly disconnects and most times I can toggle the WIFI on the phone a few times ...
- Aug 28, 2026
Turns out, if IPV4 is set to manual, automatic DNS doesn't work on iPhone/iPad. The DNS has to be set manually as well. Not sure why this wasn't a problem with v9.13.2.1, but it is now.
I cannot replicate this behavior on my PC as there is not an automatic DNS option, DNS must be set manually when setting a manual IP address.
At any rate, I think this is the solution: when setting a manual IPV4 address on an Apple device, scroll down to the DNS settings and configure the DNS manually as well - Automatic DNS does not work in this case.
I'll write this down to user error, I guess, uncovered by new firmware behavior.
bullm00n
Aug 13, 2026Virtuoso
Interesting results so far...
so far, no more disconnects on the iPhone 17 Pro after enabling WPA2 and WPA3 on the WiFi 7 main SSID. It's only been 24 hours but looks promising. But why? And why did I choose that as my first thing to try? Gut feeling? But I'd been using WPA3 only on that SSID for months with the previous firmware and possibly longer - no idea how long, really. I'll give it a few more days, and if solid, will flip it back to verify.
Aug 13, 2026Guru - Experienced User
There are still some bad behaviors with IPv6 and Apple devices using WiFi7 that NG is aware of.
