bullm00n
Aug 12, 2026Virtuoso
Firmware 12.1.11.10 iPhone disconnects
After quite a good run with the previous firmware, this update is causing issues again with at least my iPhone. It randomly disconnects and most times I can toggle the WIFI on the phone a few times ...
- Aug 28, 2026
Turns out, if IPV4 is set to manual, automatic DNS doesn't work on iPhone/iPad. The DNS has to be set manually as well. Not sure why this wasn't a problem with v9.13.2.1, but it is now.
I cannot replicate this behavior on my PC as there is not an automatic DNS option, DNS must be set manually when setting a manual IP address.
At any rate, I think this is the solution: when setting a manual IPV4 address on an Apple device, scroll down to the DNS settings and configure the DNS manually as well - Automatic DNS does not work in this case.
I'll write this down to user error, I guess, uncovered by new firmware behavior.
bullm00n
Aug 15, 2026Virtuoso
Thought that was going to be the solution - guess not :(
Not sure which to try next...channels or IPV6... not optimistic about either.
Aug 15, 2026Guru - Experienced User
Disable IPv6. And try manual channels 1 and 40. I'm currently using 1 and 40 here and iphone keeps connected on wifi.
