bullm00n
Aug 12, 2026Virtuoso
Firmware 12.1.11.10 iPhone disconnects
After quite a good run with the previous firmware, this update is causing issues again with at least my iPhone. It randomly disconnects and most times I can toggle the WIFI on the phone a few times ...
- Aug 28, 2026
Turns out, if IPV4 is set to manual, automatic DNS doesn't work on iPhone/iPad. The DNS has to be set manually as well. Not sure why this wasn't a problem with v9.13.2.1, but it is now.
I cannot replicate this behavior on my PC as there is not an automatic DNS option, DNS must be set manually when setting a manual IP address.
At any rate, I think this is the solution: when setting a manual IPV4 address on an Apple device, scroll down to the DNS settings and configure the DNS manually as well - Automatic DNS does not work in this case.
I'll write this down to user error, I guess, uncovered by new firmware behavior.
bullm00n
Aug 28, 2026Virtuoso
I will keep the IPV6 thing in mind, but as best I can tell, it was not the problem - not sure it works 100%, but I don't think that it was causing any issues. Based on what you are saying, the IPV4 DNS thing has been a long-term issue that I just didn't notice because IPV6 was working so well and the DNS problem was masked. But this latest firmware in the "12.s" versus the older "9.s" must have changed that. I had been running for probably near a year with "dead" IPV4 on my phone. :D
