Chuck_M's avatar
Chuck_M
Mentor
Jun 26, 2025
Firmware Upgrade Files Fail on RBE970 & 971
Update:  Disregard, after second attempt it took it.
Will provide results.
Regarding the firmware links on the Netgear Support site for RBE 970 and RBE 971 ...
The files are found at:
https://kb.netgear.com/000066739/RBE970-RBE971-Firmware-Version-9-13-1-2
Both firmware files downloaded (and extracted).
Both the satellites and router report invalid files and rejects the upgrades to V19.13.1.2
Would be interested if anyone has success in installing these.
  • Mine and others got it updated via AU.
    What browser are you using? Happens in other browsers, MS Edge, Firefox or Opera?
    Be sure to clear out all browser caches before trying the manual update path.
1 Reply
  • FURRYe38's avatar
