Bentlauritsen1
Sep 26, 2026Tutor
Firmware V12.1.11.15_5.4.12 on RBE971
Hi, I have a Tado internet bridge connected to an RBE970 satellite LAN port. After firmware update the bridge lost network connection. When moved to a network extender the bridge works again, so s...
Sep 26, 2026Guru - Experienced User
Does this device work when connected to the RBR?
What was prior FW version that worked on the Orbi system?
Factory reset and setup the Orbi system from scratch to check this?
Bentlauritsen1
Sep 26, 2026Tutor
Don’t know, its not possible for me to move it.
checked the log, there is no mention on what firmware version it was updated from.
As I’m disabled because of surgery in the right foot, it is not possible for me to do, the satellites are out of my reach, and i have to move them to router to connect.
- FURRYe38Sep 26, 2026Guru - Experienced User
Maybe have a friend, nieghbor or family member help you out?
