Bentlauritsen1
Sep 26, 2026Tutor
Firmware V12.1.11.15_5.4.12 on RBE971
Hi, I have a Tado internet bridge connected to an RBE970 satellite LAN port. After firmware update the bridge lost network connection. When moved to a network extender the bridge works again, so s...
Bentlauritsen1
Oct 19, 2026Tutor
As this a new ‘feature’ introduced by a firmware update, I wold like to know if it’s something Netgear will correct in a new firmware update or leave as-is?
I haven’t received any information that Netgear would be stopping support for 10 Mb/s, half duplex in new firmware.
I’m not so well funded that I’m able to change my whole Tado setup ;-)
Oct 19, 2026Guru - Experienced User
I would not call this a new feature. More like limitation.
The quickest work around this is to get you a cheap GS105 or GS305 LAN switch in between the RBR/RBS and these devices that only support 10Mbps. What I did with my devices that only support 10Mbps. I have a few.
I haven't either and had noticed that my devices were not connecting with Orbi BE series.
