CAL-GB
Jun 15, 2026Tutor
Frequent drops, crashes, and network noise…how I fixed it
For about a year and a half, I dealt with frequent drops on my Orbi system. A couple months ago, I got serious. Drops were daily, sometimes multiple times. I have about 150 devices, mostly Lumary rec...
Jun 16, 2026Guru - Experienced User
Have heard of many IoT smart bulbs causing problems for wireless systems over the years.
Having that many devices as well, I guess would be problematic for sure.
Which fan did you find for the 970 series?
Definitely use a fan on top of my RBR971. I always recommend a fan on top or under any router. Been using external cooling for years now. Saves the hardware from heat damage over the life.
CAL-GB
Jun 16, 2026Tutor
https://www.amazon.com/dp/B07R659J8Z?ref=ppx_yo2ov_dt_b_fed_asin_title
- FURRYe38Jun 16, 2026Guru - Experienced User
Kewl, Will keep this on my fan recommendation list. I have something similar but with rubber feet. They work great to keep these cooler.
Glad you found the fix.
Be sure to save off a backup configuration to file for safe keeping. Saves time if a factory reset is needed.
Enjoy.
- CAL-GBJun 16, 2026Tutor
Good idea. What fan did you use? I have all my Orbis on a wall mounts. I like the look and the cable management I can build with a wall mount unit. I took a gamble when buying this fan and it fits perfectly. The feet sort of lock the fan to the router, rather than just placing on top and risking falling off if simply bumped. The feet act as a locking mechanism keeping it in place very sturdy.
I found these a while back:
https://www.amazon.com/SCCCF-Portable-Playstation-Receiver-Computer/dp/B0CW9H1381/
Works well on top of units or underneath for other units were the vent may have better placement.
Rubber feet are nice and soft and don't scratch the surface.
