Davek77
Sep 15, 2025Aspirant
Help save my marriage 🤣
Heys guys Sky Q Sky hub 4.2 orbi rbr850 with 2 satellites. so I’ve tried to get this working myself but the tech terminology has me frazzled. As sky doesn’t allow bridge mode I put m...
Sep 15, 2025Guru - Experienced User
What speeds UP and Down do you pay for from the ISP?
Test a either net connected PC connected to the ISP router to check.
Be sure your using a good quality LAN cable between the modem and Orbirouter. CAT6A STP is recommended.
What Firmware version is loaded on the Orbi system?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
Does the SkyHub have a DMZ? If so, try the Orbi system in router mode in the Hubs DMZ.
Orbi Systems Manual Factory Reset Process | NETGEAR Communities
Static IP Address Configuration for AP Mode | NETGEAR Communities
