mapotter99's avatar
mapotter99
Apprentice
Jun 03, 2026
How do I downgrade my Orbi 973 from V12.1.8.7 to V9.13.2.1???
I was holding on to version 12, but I have enough things that aren't working right, including using Open VPN to access my home network while away from home, that I need to get to a stable build.
I attempted this downgrade, starting with the satellites, but they tell me:
"Firmware Downgrade Not Allowed. The firmware version you are trying to install is older than version 9.13.3.1. Please install firmware version 9.13.3.1 or newer."
Thanks
  • FURRYe38's avatar
    Where did you get v12 from? That version was pulled the same day it was posted. Was not supposed to be released from what I was told.
  • I got it that day while it was public. I installed it and stuck with it, but now that I’ve noticed functionality I need not working, I want to downgrade.
  • For those who plan to downgrade, Furry can send instructions.
    but involves factory resetting the system and setting up from scratch.
    I’m out.
    Ubiquiti WiFi 7 setup will be here tomorrow.
    I look forward to the catharsis of tossing this $2000 Orbi beta product into the electronics recycling container after 3 years of frustration, with no end in sight.
