redheadkxc
Jul 03, 2026Aspirant
How many satellites for WiFi 7 in tall old home?
I have an Orbi RBR50 with three satellites in my 3-story, 125-year-old home with lathe plaster walls. The RBR50 is on the 2nd floor, satellites on the 1st and 3rd floors and an outdoor unit in the ga...
- Jul 03, 2026
I would go with with same amount of RBS units. You can start off with one less at the beginning to see how the system works for you and if you notice that your not getting good coverage as before, then deploy the 3rd one.
redheadkxc
about 3,600 square feet and yes, lathe plaster walls, several chimneys, gas lines in some of the walls from when the house had gas lamps (pre electricity).
Jul 03, 2026Guru - Experienced User
