redheadkxc
Jul 03, 2026Aspirant
How many satellites for WiFi 7 in tall old home?
I have an Orbi RBR50 with three satellites in my 3-story, 125-year-old home with lathe plaster walls. The RBR50 is on the 2nd floor, satellites on the 1st and 3rd floors and an outdoor unit in the ga...
- Jul 03, 2026
I would go with with same amount of RBS units. You can start off with one less at the beginning to see how the system works for you and if you notice that your not getting good coverage as before, then deploy the 3rd one.
redheadkxc
That was my inclination. Thanks for the swift and useful replies. Have a good weekend.
- FURRYe38Jul 03, 2026Guru - Experienced User
Hope it all works out for you. Come back here if you need any help or more information.
Have a great weekend and Happy 4th.
