Woolly4U2
Aug 23, 2025Aspirant
how to change the device connection type from 2.4ghz to 5.0ghz
I want to change the connection type for several devices from the current 2.4ghz to 5.0ghz, but cannot find instructions on how to do that. Can you help me out with this issue? Thanks.
CrimpOn
Aug 24, 2025Guru - Experienced User
Without knowing which devices are involved, it is difficult to make suggestions. There have been posts about devices that are capable of both 2.4G and 5G WiFi connecting to 2.4G when the user expected them to connect to the 5G signal.
