DocRJNC
Dec 09, 2025Tutor
HP Printer Won't Connect to Router
Good evening. I just upgraded from 850 to 970. All looks good, except my HP Printer won't connect. I have tried using the printer's menu and the HP Smart app. The printer detects the route...
- Dec 10, 2025
Good afternoon.
Thanks for the reply. After looking at several entries in the community; the IoT option kept grabbing my attention. It did show up in the router listing, but I ignored it. So, i tried connecting to my IoT network and I got connected immediately.
Thanks for all the responses.
DocRJNC
Dec 10, 2025Tutor
Your response to check the IoT network got me moving in the right direction. I guess the 970 is way smarter than I am.
Thank you.
Dec 10, 2025Guru - Experienced User
Glad your going in right direction. Ya, having WPA3 in the mix causes some older non WPA3 devices to not work right or connect. Even though they don't support WPA3, seems there is a odd mis-handling of the connection handsake if WPA3 is on the signal and these devices don't know what to do. The separate IoT network you can select WPA2 only and should resolve this.
DocRJNC wrote:Your response to check the IoT network got me moving in the right direction. I guess the 970 is way smarter than I am.
