Guru0006
Oct 05, 2026Aspirant
I am getting single digit speeds
I am having even worse issues here as I use my LoT network as my 2.4 ghz only one and my older ring cameras dont have 5 ot 6 ghz. I am.getting single digit speeds! Even one camera that is no mor...
- Oct 20, 2026
Actually found the problem. I had disabled 20/40 mhz coexistence. I reenabled and voila. All is working much better now with all ring cameras meeting their requirements.
Guru0006
Oct 20, 2026Aspirant
Oct 20, 2026Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
