chmnda
Jun 03, 2025Guide
I Finally found a solution to fixing the ORBI970 iPhone WIFI disconnecting issue
I had frequent Wi-Fi disconnection issues with my iPhone on the Orbi 970, and after some trial and error, here are the steps I took to resolve it: Adjust Wireless Channels and Security Settings
Jun 03, 2025Guru - Experienced User
Maybe a good solution for newer Apple Iphones, however setting Security to WPA3 only will cause all other non supporting WPA3 devices, to not work on the main WLAN.
Does those Advanced Setup configuration settings work with mixed mode WPA2 and WPA3 enabled or do you still see odd problems with the iphones?
chmnda
Jun 03, 2025Guide
so far, no wifi connection are dropping for the iPhones 15 and 16 in my household.
- FURRYe38Jun 03, 2025Guru - Experienced User
- chmndaJun 03, 2025Guide
you can try that. I am not sure on separate things that are set differently from the list of stuffs that I have changed above. So for the combo of all those stuffs changed above, solved the wifi dropping issue. in terms of one that is not changed (for e.g your case of the WPA2/WP3 mixed mode), I am not sure about it.
We need to check those settings with mixed mode enabled and see. If problems continue with mixed mode and your new config settings, then may point to something in having mixed WPA modes enabled where WPA3 only helps or doesn't cause problems. If the problems are not seen with mixed mode enabled, then may point to something in the Coexistance/Preamble Mode could be causing issues.
Trying to help narrow down a bit further on this.
This is good information though.
