PimpDiggler
Aug 20, 2025Guide
I have a 970 that doesnt see close to linespeed with overhead taken into account
PimpDiggler
Aug 20, 2025Guide
When I was on GFibers 8/8 gig plan their router's speed test netted 8/8 each way the Orbi 970 would only go 7.5/7.3
Aug 22, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
GFibers is the ISP you are with?
I presume you are speed testing with a ethernet connected PC capable of also high connection rates, i.e. 10Gb?
What was speed results seen at the PC and when using the RBR onboard speed test app?
- PimpDigglerAug 22, 2025Guide
Orbi 970 no satellites with the latest firmware
Google Fiber the ONT Model is GOXP330C Intertek
Yes testing with ethernet and yes my equipment in here is capable of 100Gbs the switch connected to the router is a Netgear XS508M.
