BARON1234
Mar 17, 2026Follower
I have the 770 with two satellites
I have the 770 with two satellites. Everything works fantastic easy connections. The problem that I have is we game with Quest headsets. We have constant drops and reconnects while gaming. Until rece...
Mar 18, 2026Guru - Experienced User
Possible maybe too much wifi signal saturation or over lap between the RBR and RBS in the home. If you turned OFF the one RBS in the home, and now its working well, points to this being the main cause.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
