millerm77
May 16, 2025Aspirant
I have the latest firmware update, but my Orbi RB971 (w/2 satellites) keeps disconnecting
I know this is an older thread, but I too am having the same issues. I have the latest firmware update, but my Orbi RB971 (w/2 satellites) keeps disconnecting. We are having trouble making calls as...
May 16, 2025Guru - Experienced User
Does front LEDs on RBS turn PINK when this happens?
Are RBS ethernet or wirelessly connected to the RBR?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter.
