msroach
Dec 14, 2025Follower
I have two directly wired backhauls through MOCA
Hello similar experience they told me they would replace the 960s if I bought the 970s. So I spent over $4,000 on the 970 system and then when I sent back to 960s they said... oh it's been more ...
CrimpOn
Dec 14, 2025Guru - Experienced User
Would be useful to know which specific MoCA adapters are in use.
I used MoCA for some time to connect a Tivo receiver, Tivo remote, and their internet connection to my router. Switched to Powerline because I did not have coax to a specific location, and found that Powerline fell short. Using WiFi backhaul to satellites now - sigh.
Do the satellites function correctly using the WiFi backhaul and go into config sync when they are connected to MoCA?
