VINE0001
Sep 22, 2025Aspirant
I manually updated to 10.5.20.3 on my 770
I manually updated to 10.5.20.3 on my 770, and after the update was not able to access some websites via a Mac running MS Edge. Strange that using Safari I could access those sites, but not with Edg...
VINE0001
Mac mini and MacBook Pro, both running Tahoe
Armor is enabled, and IPv6 was enabled I believe. Didn't try Firefox.
I may try updating again and after the update reset the router to factory settings and setup as new and see if that fixes the problem.
It is strange as I can ping those websites but for whatever reason, Edge will not open them while Safari will with no issues.
Sep 22, 2025Guru - Experienced User
I'll try this on my Mac Book Pro with Beta 15.something on it and load MS Edge on it and test with my 870 series.
If you re-update, I would test with Armor and IPv6 disabled, thru Orbi app and on the RBR.
Using ISP DNS or custom DNS?
What brand and model# is your ISP modem or ONT?
