VINE0001
Sep 22, 2025Aspirant
I manually updated to 10.5.20.3 on my 770
I manually updated to 10.5.20.3 on my 770, and after the update was not able to access some websites via a Mac running MS Edge. Strange that using Safari I could access those sites, but not with Edg...
donawalt
Sep 22, 2025Hero - Experienced User
FWIW, I tried it on an Orbi 970 router, latest FW, and all 3 of those sites came up fine for me as well.
I’d these on one machine first; if it fixes it, repeat on the others:
1. New InPrivate window → test.
2. Disable extensions (edge://extensions/) → test.
3. Flush Edge networking:
• edge://net-internals/#dns → Clear host cache
• edge://net-internals/#sockets → Flush socket pools
4. Also - can you try another DNS, like 8.8.8.8 (Google) or 1.1.1.1 (Cloudfare) manually entered on the Mac?
I might have some other suggestions if these all fail...
