VINE0001
Sep 22, 2025Aspirant
I manually updated to 10.5.20.3 on my 770
I manually updated to 10.5.20.3 on my 770, and after the update was not able to access some websites via a Mac running MS Edge. Strange that using Safari I could access those sites, but not with Edg...
VINE0001
Sep 23, 2025Aspirant
After troubleshooting this morning, determined that the issue is indeed IPv6. When I disabled this setting after updating the firmware, MS Edge was able to access apple.com and wsj.com with no issues. I am not sure what setting within IPv6 would be causing this, but I am going to leave it off for now and do a bit more research to see if I can determine what exactly is the issue, and why it only affects MS Edge and not Safari browsing.
Thanks to you all for your suggestions and assistance.
Sep 23, 2025Guru - Experienced User
Interesting that only IPv6 enabled on the RBR causes this with MS Edge browser. All other browsers were good with IPv6 enabled on the RBR and Mac PC?
