sysop
Dec 11, 2025Tutor
I move around between the three (1 Router) and (2 satellites)
NO, it does not. Now when I move around between the three (1 Router) and (2 satellites) I have IOS devices that I literally have to turn OFF the wifi for 15 seconds and turn it back on to get it to w...
sysop
Dec 18, 2025Tutor
I had already sent it to NG but ok. Thanks for your help.
I think you mean Advanced, Internet Port, Connection status. By the time I get to this the connection has already restored.
Dec 18, 2025Guru - Experienced User
Ok. Thank you for this.
I passed to the Orbi team. Hoping maybe they can help with a beta FW after they can make some adjustments after there review. Been seen similar problems with users and ISP ONT with NG routers. Seems to some mis-handling between them. We've made NG aware of it.
If you need to put something else online for stability, go for it. Will check on this as NG may need some time to figure it out and get a fix in.
- sysopDec 18, 2025Tutor
Yes, I would like to keep the Netgear in the end. But for now I need to do some testing with something else and see if I can make the issue go away on my own until they figure it out.
