kiyong
Feb 22, 2026Follower
I need 220v power supply for RBE362
I bought the U.S version of the RBE362 model, and it came with a 110v adapter. However, I need a 220V adapter. Could you tell me how i can purchase a 220V adapter compatible with the RBE362?
CrimpOn
Feb 23, 2026Guru - Experienced User
You face several issues:
- 110v vs 220v. Sometimes, Netgear has used multi-voltage power supplies and simply put a 110v label on them for the US market. The only way to tell would be a potentially costly experiment.
- Physical plug. The US style plug is different from electrical plugs used in other countries.
- The power connection must match the factory connector in size and polarity.
Using appliances manufactured for the US in other countries is a common situation. It might be worth considering a combination voltage/plug converter appropriate for your location.
